Hey guys and gals, today i am posting a few pics on how i installed my garmin amps rugged mount to my t7, i used the rally raid top mount to mount the garmin amps rugged mount to the top bar above the instrument cluster, i chose to run the wiring down the right hand side and used the oem connector to wire directly to the stock accessory spare connector,this 3 pin connector is for the grip warmer the left hand side is for the fog lamps, the flat 2 pins on either side is for the lighter socket types, i used the connector MT090-3 from link here the rally raid site can be found here rally raid link , i chose to wire the + to the lower right hand terminal as the power is switched with the key, can be seen in the below wiring diagram, hope someone can find this post helpful.
Edited by iKeoxD
Nice clean install and yes, you used the correct auxiliary connection.  I wired mine the same way for a fused, switched power source.
updated the post as i said the connector on the right hand said was for the fog light i was incorrect, right hand side 3 pin is for the grip warmers left hand side 3 pin is for the fog lamps.
Edited by iKeoxD
That looks good.  It appears to take the GPS cradle out further forward than the bike's dash.  Does it touch?
Also, does your mount have a bit that sticks out on the bottom?
I've got a 595 and looking at mounting options.  I think the fat bottom on the holder could be an issue for clearance/lining up bolt holes?  But perhaps the mount will move this all out more and not be an issue?
I orederd the spacer kit that comes with the rally raid mount takes it out 10 mm more
