Clearwater lights
Copentx
I have a set of Darla Clearwater lights that I took off my bmw F800 GSA prior to selling it to transfer to my T7. It has the dial to set the intensity of the lights that I am mounting to the handlebars.
The setup requires a switched power source for the lights. The wires are only long enough to fit under the seat.
is there a switched power under the seat?  I know there is one under the front fairing, it just isn’t long enough to tap into. The back brake lights are also a ways back.
I have considered getting the eastern beaver power block (pc8) and wiring that in to have all the power I need, but I don’t have it yet.
thank you!
thank you!
Please look closely at healtech-electronics.com Thunder box. takes all the issues out of adding "switched" accessories
Neil, that is a brilliant way to add switched accessories.  I will still use a relay with a diode to send a signal to a Skene controller to control my Aux Lights.  I like the Skene dimmer a lot and will have it on my T7 as well.
