**SOLD**
GreatDistances
**SOLD**
(1) B&B Off Road brand rear compact tail rack luggage plate extension for Yamaha Tenere 700, in black PPA coating. Mounting hardware included (3 bolts, 3 spacers). Never mounted, no damage.
Asking $30.00 plus actual shipping costs in USA, paid by F&F PayPal. Shipping from zip code 63118. Package will weigh about 3 lbs. I can ship via USPS or FedEx.
Worth noting - the bolt holes on this particular luggage plate were not countersunk so the bolt heads stick up a small amount above the plate (pictured below in last two pictures). This is not the way B&B normally does it. If you are handy with a drill press, you can countersink these bolt holes yourself to make the bolt heads flush when inserted.
Website description from B&B for the compact tail rack luggage plate extension for Yamaha T7:
  • Model: XTZ690 /Tenere 700 Year: 2020 / 2021
  • All hardware for mounting is included.
  • Made from 5mm thick cnc machined plate
  • Weighs 1kg
  • Multiple attachments points
  • Pre drilled for Givi monokey mount system
  • Pre drilled for roto pax fluid containers
  • This listing is for the Rear luggage plate only
  • Dimensions 25cm x 26cm flat surface
  • Does not include Pillion handles or base tail rack.
IMPORTANT NOTE - you need the B&B Off Road rear compact tail rack for the Yamaha T7 in order to mount this additional luggage plate. The luggage plate that is for sale only mounts to the compact tail rack and cannot be mounted by itself. The compact tail rack itself does NOT come with this listing and I do not have the compact tail rack for sale.
Thank you, any questions, just ask.
IMG_7108.jpg.654fef434caed967d5f218dd102b6abe.jpgIMG_7109.jpg.ff3591c3d5db5efdaf35e48682f3dfe7.jpgIMG_7110.jpg.9f18cdf38d0a8c7144727fc811b96220.jpgIMG_7102.jpg.1264eceb6f252a02f5c0be7717f5f1ce.jpgIMG_7107.jpg.57ea553e143d2105790fbfbd0f088a97.jpgIMG_7106.jpg.cc64cd22f73bbb876bde29efdaed5c8e.jpg
Edited by GreatDistances
item sold
bump with price reduction to $30 + ship.
  • 8 months later...
Interested if this is still alive.
If you put @GreatDistances, he'll be notified of your inquiry.
And here I am!  Yes it is still available.  I’ll send you a private message on the topic @Texas700 .
  • GreatDistances changed the title to **SOLD**
