Added light bar - need a relay
truckirwin
Careful with the DIY harness for the headlight switch, you could toast the entire headlight. A few have done so, and its a costly mistake. Cyclops wrote about it and sells a harness, however not sure it can be bought separately. I got the Cyclops lights before they had the headlight switch option
1 hour ago, truckirwin said:
I added this light bar:
https://www.amazon.com/Nilight-40001S-B-Mounting-Brackets-Warranty/dp/B0197ZQLBA
Now I need to wire it up - looking for a relay or a wiring harness package that will do the trick. Any recommendations?
Going to wire it into the high beam switch.
Any info appreciated!
Truck
Just use the search option.
There is a thread about it. I have these YuouTube video's in my watch later list for when i get to my LED bar install.
I have it installed this way tonight.
Don't know if the relay had a diode, it's a Hella 4ra 003510-081 i had in stock and it works.
An extended blog about my work from last weekend and tonight will be posted in my blog for the upcoming weekend but this is how it looked just before i put the panel back up.
