Replacing OEM switches
Everything Tene
Hi guys!
just wanted to share my little mod.
so anyone deciding to go with another left hand side switch, can see the wiring and colors for the different OEM switch functions.
I put CEV style switches from KTM enduro bikes, just to be able to mount both my Terrain Command controlled on the left side (to cramped with oem)
I didn’t cut any wires, just used my soldering iron to remove the cables from the OEM switches. This way I can always turn it back to stock if need be.
on thing, these CEV style rocker switches suck LOL, they will not like water and are prone to cause glitchy short circuit behaviors.
this if you do not seal them up, so some silicone or hot glue is a must.
just ask any Enduro rider who is used to these and they will tell you.
Edited by Everything Tene
Spelling
