Posted March 25, 20223 yr I have disassembled the side panels to mount the protection bars, I find myself with these rubber shims... does anyone know where they are mounted? thank you
April 4, 20223 yr Did you figure it out? If not, here is a diagram that might help you. Edited April 4, 20223 yr by Yasenia
April 22, 20223 yr They go on the backside of these 2 bolts. The are just there to cover the exposed threads on the bolts that protrude out the back of that bracket. Someone must have been worried about corrosion starting on the bolts? Edited April 22, 20223 yr by williestreet
