Posted April 10, 20223 yr Just fitted the above tank straight forward easy to fit but it will not fit with the T7 rally tail tidy the LH rear indicator is at the same level as the filler neck so i had to replace the OEM tail piece but with the rear rack it don't look too bad.
April 11, 20223 yr Author Went to Salisbury and back on a tank full 265 miles 19.44 ltrs out of 21 ltrs mostly motorway/dual carriageway should get better on A/B roads. The bike uses the 5 ltrs in the aux tank first so once the fuel gauge moves you know the aux tank is empty,
April 11, 20223 yr Community Expert Currently in Cyprus (no problem) but it’s looks scarce at home (Folkestone)
