Stoltec Moto Penske Rear Shock
Simmons1
After 2 trips of the rear shock to an expensive suspension shop I bit the bullet and bought a Penske Triple Clicker from Stoltec Moto.
The original suspension shop did an ok job with the OEM shock except on high speed compression hits that really hurt my fat old man back.
The Penske is an amazing improvement right out of the box.
I'll bet that is an amazing upgrade, especially if you are a bigger rider like me.
Penske shock comes sprung?
What do you weigh and what spring psec did they use?
What fork springs are you using?  revalved or other mods ?
I have repsrung with 90n rear spring and 60 forksprings..much better but both ends need help...harsh high speed compression damping and not enough rebound....and they bottom hard both ends
Im 90kg naked....100kg ready to ride and lightly geared
Thanks
Thanks
The new shock is sprung and valved to your weight, accessories used and riding style. The shock eliminates the nasty harsh high speed compression issues at the rear. Mine has a 600 pound spring.
The forks were resprung and revalved by the shop that originally did rear shock. The forks have 6.6 springs and could probably be a little stiffer yet but work pretty well. If Stoltec had a fork kit when I originally did the forks I would have used it.
To get better answers I would contact Nick Stoltec directly.
https://stoltecmoto.com/
Edited by Simmons1
