Lowering links
Mapbook
I am considering a set of links to lower the saddle by 20mm as i am struggling to get my leg over (no pun intended)
how will this effect the handling?
34 minutes ago, Mapbook said:
how will this affect the handling
IT HAS BEEN DOCUMENTED THAT SHORT GUYS WILL FALL LESS.
You can also change the way of getting on and off the bike.
Don't listen to those guys cause their crazy or something.
I have 20 mm lowering links and it does not seem to change anything except the bike is 20 mm lower.  I had adjusted the fork up by 15 mm and then I put them back to original and couldn't tell the difference between the 2 positions.  You won't notice any handling differences at all.
Any one know the torque values for the link bolts?
(In Newton metres)
thanks
Ta, torque is 49nm just fitted the lower links, i will try it out next week when i have fitted a set of bar risers i've just ordered.
Edited by Mapbook
update
Not to offend anyone but if you're paying attention you should notice a change in handling and suspension action from a lowering link and/or a change in front ride height.  I installed the OEM lowering link (18mm) and found the change in rear suspension action very acceptable.  I dropped the front 10mm to compensate.  With this setup the steering is slightly slower (ie, more stable but takes a little more effort to initial a turn).  Overall I like it this way, but I liked the stock setup even more.  I might test a few more mm of reduced front ride height.  At 5'6" with a 29" inseam I'm willing to take the slight degradation in handling so that I can get at least one toe down.  If you install a lowering link and leave the forks in the stock location, I think the steering would be unacceptably slow, and your front wheel traction will suffer.
I also feel that a large change in rear linkage would be bad.  I suspect 18-20mm is the most that you can go without ruining the way the suspension works, and the bike's balance and handling.
There are other ways to lower a bike if you need to drop it more, but they are more expensive and you'll lose precious ground clearance.
I also tried the OEM lower seat, and did not like it.  Very little improvement in the ability to get a foot down, and definitely less comfortable than the stock seat.
