I have a quadlock wireless charger that previously was powered through a USB port in the aux outlet on the dash. I added an eastern beaver PC8. and wired the quad lock to that and now the charging is very intermittent. It actually seems that if I just idle my bike it will charge but shortly after I start riding, it will stop charging. The light on the Quadlock changes from solid green to flashing blue which apparently indicates a problem. I know the charging unit works because if I change it back to the USB through the aux port it charges fine. I have a Zumo XT also wired to the PC8 and charges perfectly. I have changed fuses and locations on the PC8 (All switched ports on the PC8). Wondering if anyone has any explanation or suggestions??
T700NB
thanks.
12 answers to this question
Register a new accountSign in
