denali
Mapbook
Just got a pair of Denali D2 trioptic  with the data dim unit having just read all the horror stories about the headlight not working and damage to the ECU after the trigger wire for the data dim was connected to the main beam wire.
Have these problems been resolved?
Been in contact with Denali as they are ground switched main beam they this
DNL.WHS.20600_WITB_large.jpg?v=164304810
The long-awaited Trigger Wizard is a simple wiring adapter that converts a ground-switched vehicle high beam wire to a traditional high beam wire that outputs 12 volts when you turn on your high beam. This...
