Would anyone have a suggestion for sourcing my switched  voltage? I'm installing a Centech AP-2 and there are two power sources available on the fuse block, switched (power Relay), and unswitched (Battery). Thanks.
Plate light
For a switched relay you need a source that is live with the ignition on i.e. rear tail light blue wire or one of the power take offs under the front side panels look for the plug taped to the harness.
Better idea you don't accidentally leave anything on when the ignition is off.
Edited by Mapbook
