Auxillary Connectors...how many?
Mark T700
Greetings!
I'll be installing a GPS.  I want to use one of the provided auxiliary connectors.   On other bikes, I used the OEM provided two wire ignition-controlled auxiliary without problem.  Those bikes only had one connector to use if one wanted keyed power with adding relay or a junction box.
How many two-wire and three-wire auxiliary connectors are provided?  Are they all ignition switched?  Is the three-wire connector for heated grips or for CAN messages.
Thanks!
2x 2 wire, 2x 3 wire.
AFAIK all ignition switched.
3 wire for headed grips, no CAN.
@Mark T700 The 2 connector plugs are switched/ fused 2A auxiliary leads. The 3 connector plugs are switched/fused 10A leads suitable for heated grips.  Wiring diagram is on the last page of this link.
Has anyone used the four & three pin plugs under the seat?
They are labeled USB, CAN & IN.
See photo
Edited by James
Typo
