Pass light not working
Markjct700
Hi all, I have recently spotted my pass light doesn't work. When I use the main beam switch all 4 led headlights work but when I use the pass switch it doesn't flash or light up. I have checked all fuses, I have opened the switch and it has 12v when pressed, where should I try from here? Any help much appreciated
Thanks
Mark
@Markjct700 On pg 471 in this manual, the dimmer is #75 and the pass switch is #76.  Both feed the hi/ lo light circuit so if you're getting 12v out of the pass switch, my thought is a lack of continuity from the 12v feed from the pass switch to where it connects with the dimmer switch, which you state is working as advertised.
Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
Hi AZJW , really appreciate your reply, that pdf is so useful, I will investigate further now I understand it better, thanks for taking the time to post
@Markjct700 My pleasure,  hope you get it sorted. Please follow-up here when you get it figured out as sharing our trials and successes here benefits all.
I have had the same issue but found that if I held the switch in and jiggled it up and down it would work again. Spray some WD40 into it and jiggle it.
