B&B rear compact rack compatibility
Camstyn
I’m looking for a low profile rear rack and I’ve narrowed it down to the B&B and the Altrider, the latter of which is bigger than I’m looking for.
I have a Kriega soft luggage setup with the Tenere specific OS-Base that uses the rear bobbins for securement, and a Touratech pannier rack for big trips which also secures using the bobbins mounting locations. Also have a CamelADV tidy tail.
Anyone else with the B&B rack, are you able to use it without losing the use of the rear bobbin mounts for luggage systems like what I’ve got? I’m sure it can be done but just wondering what kind of headache I’m going to run into using these items together.
I have the B&B rack. I doubt it will be a straight bolt on option but I'm sure you will be able to make modifications easy enough.
