GIVI S250 box and DIY bracket
365moto.eu
Hi from Italy,
it had been a while since I wanted to install an external toolbox that would allow me to access the tools without lifting the saddle.
I then had a friend make an aluminum bracket (4 mm) partly pressed and partly welded.
Of the 8 attacks planned by GIVI I managed to use 6, but the whole is very very solid.
So I was able to install the GIVI S250 toolbox without needing the classic rigid side frames. In fact, I used the side supports of the Adventure Spec.
Edited by 365moto.eu
I run the same box.
Similar mount underneath, but I use all 4 bolts under the tail and a small strap on the outside for some extra support.
