Brake light stuck on
mrboni
The brake light is stuck on. I didn’t clock exactly when it happened but i did adjust the rear brake pedal recently so thats a good guess 😅
 I’ve set the pedal roughly back to where it was and the light is still stuck on. Any ideas?
The brake light switch is adjustable. You just need a 12mm (10mm?) hex wrench and page 3-29of the service manual:
Edited by Tenerider
2 hours ago, mrboni said:
Ah that's brilliant.  I must start searching the manual before posting...
Thanks
Don't worry, sometimes searching the manual isn't helpful 😅
I recently noticed there is no manual info on how the chain rollers need to be mounted.
Hope you get your lights working as intended soon!
