Hello, Short story, was riding the T7 on a trip and one of my main frame-to-engine bolts ripped out taking all the aluminum threads from the engine with it. As much as I would like to blame Yamaha for this as a defect, I know it's the tech at the dealership who likely over tightened the bolt while mounting the crash bars. Fortunately, I was able to remove a washer/bushing and get the bolt back in enough to grab just a couple of the threads that were left, and head home.
I think I am likely going to have to tap and heli-coil the engine. But, if I do that I wouldn’t be able to drill the next size larger hole (to tap to make room for the coil) with the frame directly in the way? (Unless I drill the frame hole a little larger too which seems like a bad idea) I think I may have to drop the engine ?
This is the offending bolt in question (right side of the engine), after I removed the washer and re-installed it.
DT675
24 answers to this question
Register a new accountSign in
