Racetorx gear shift support.
Stevoh
YouTube threw up an install and review of a Racetorx gear shift support for T7, I'd never heard of such a thing, claims to give cleaner shifts by limiting lateral movement of the gear shifter shaft, has anyone fitted this bit of gear?
Eliminate false neutrals is part of the blurb on their website, not an issue I get very often, but now and then refuses to shift between 3 and 4, I've heard others say the same, just might be worth 77€😲 if it can stop this, what do you think?
Marcus from the video is here on the forum so yeah, someone here fitted it.
Just keep your chain at the right tension and the gear changes will be good, no need to buy some weird "fix" for stuff that aint broken.
Check my gear shaft.  No discernable play.  If you need that, fix you gearbox rather.
  • 7 months later...
If you are thinking of trying one of these, there are less expensive versions on eBay.
I have been thinking of trying one of those but won't fit with my r&g case guards.
