Found-OEM heated grips.
AZJW
Looking for a set of Yamaha OEM heated grips and associated wiring. Out of stock currently and hoping someone has an uninstalled set and went with something else.
Part # B67-H29A0-V0-00
Have had a set on my T7 now for almost 2 years. Thinking about pulling them of and replacing them with something else. They are not that hot, and the grips are quite hard. More like plastic than a rubber grip. Not very comfortable in rough terrain.
If I was in your shoes, I would get the factory plug(s) from Eastern Beaver and wire up some under grip heaters with  a nice set of MX grips on top.
Thanks for the feedback,  but I've had the oem heated grips on my T7 for over 2 years and think they're fine. Needing a second set for my son's T7.
Yamaha quit sell them because they are not very good. Mine barely warm up. (Yamaha part)
Yamaha has a new part number for heated grips. Just ordered them last month. ETA 3-November.
Got a link you can share or did you have to go through a Yamaha dealer?
OK, Heated grips.
Couple weeks ago Yamaha Canada was showing 2 part #'s for heated grips on the web site.
GA Checkpoint said they were the old and new #'s and ordered me the new part. Said both included the cable to plug into the triangular 3-pin harness connector but not the grip spacer.
Today both old and new part numbers  are non-existent on the yamaha-motor.ca website. And I can't remember what they ordered.
Looking deeper
YME-F2960-10-00 are the 'discontinued' grips with cable that require YME-F296E-00-00 grip spacer
B67-H29A0-V0-00 is what I think Checkpoint ordered - same as the YME grips  but requires the YME spacer and BC6-H253L-00-00 Grip Warmer Connector Cable.
We'll see what shows up. I understand the Yamaha T7 grips are programmable - different heat levels for scooter, dual sport and ADV bikes. Don't know if those that complain they aren't hot enough have not programmed them correctly?
Edited by Black99S
I have a brand new set sitting on the shelf.  They came with my bike, but I dont need them in Hawaii.
@Chris618 Pm inbound
  • AZJW changed the title to Found-OEM heated grips.
Thx @Chris618 !
