OEM Bar: what is the sweep mm / deg.
ADVUSA
Renthal Worksfit tool is a great tool to compare current bars with options you are considering.
Open link --scroll the left menu down till you see the tenere stock bar(831-50)
Use the right menus to select a bar you are considering and it will overlay both bars so you can see exactly how they change your position.
And the short answer is 50mm.
Edited by williestreet
That quite a handy tool.  Am I they only one that doesn't like sweep back? It sort of puts hands into unnatural position
Edited by Redbikejohn
