T7 Engine Problem (Lost Cylinder)
Justin
I assume the Rapid Bike EVO recalibrates the ignition timing, so would need an intervention connector from the crank position sensor. The error codes suggest the crank and injector timing was out, or not reading at all, suggesting a temporary malfunction of the RB EVO.
13 hours ago, Justin said:
@PNGL thanks a lot for telling me this, that is very reassuring to hear! šŸ™ What type of other splicing method you used? I could buy it and just do the same as you.
Soldering is best, but I can't solder worth a damn. I used one of these instead and haven't had a single issue since.
https://www.amazon.com/dp/B077YB123S/ref=redir_mobile_desktop?_encoding=UTF8&aaxitk=77446ab47cc4015762862f0635f4980c&content-id=amzn1.sym.552bcbb2-81a1-4e8b-b868-3fba7d5af42a%3Aamzn1.sym.552bcbb2-81a1-4e8b-b868-3fba7d5af42a&hsa_cr_id=1989203900101&pd_rd_plhdr=t&pd_rd_r=da791f92-940a-4f44-bad7-12501b2982fb&pd_rd_w=EaeQF&pd_rd_wg=sUhPo&qid=1669808768&ref_=sbx_be_s_sparkle_lsi4d_asin_0_title&sr=1-1-9e67e56a-6f64-441f-a281-df67fc737124
Ā
Edited by PNGL
"What the hell's a 'farkle'? Oh... I... have all the farkles." šŸ˜‘šŸ¤¦šŸ»ā€ā™‚ļø
A better choice is something like this:Ā
Ā
https://a.co/d/79UfNf3
Ā
It is designed for the marine environment and not likely to have problems with water. You need to cover it with electrical tape because the middle is not insulated.Ā
Edited by Hollybrook
Tenere700.net is not affiliated with YamahaĀ Motor Co and any opinions expressed on this website are solely those of ea individualĀ author and do not represent Yamaha Motor CoĀ or Tenere700.net .
