StegPegz + AdventureSpec pannier rac
Stevoh
Question:
Is anyone running Steg Pegz with Adventure Spec racks, it's looking like they may not be compatible??
You buy them; try them; and if they don't fit I'll take them of your hands at 50% of retail price 🤣
Sounds like a deal!🤔🤑
On 1/25/2023 at 2:36 PM, thruster said:
I run both and are compatible.
Yes, I've fitted them easy as just drill one 5mm hole and perfect, I must say I'm kicking myself for not getting ba set of stegpegz earlier, such a difference, I highly recommend!!
1 hour ago, TenereTragic700 said:
@thruster did you need to run a spacer for the Adventure Spec pannier plates to clear the camel exhaust?
Spacer length will depend on whether or not you're using a tail rack in conjunction with the side racks. Cory's website states 17mm spacers and longer bolts are needed for clearance using ADV SPEC soft bag plates with the Rally exhaust, but doesn't specify if a tail rack is included.  I'm using 19mm spacers with my RallyRaid side racks, with a tail rack and it works fine, but the clearance is just over 1/4" between the rack and muffler.
Here's the spacers I got that worked, but you'll need to factor in what length your tail rack mounts ( if used) take up before the side racks are mounted.
Aluminum Spacer 3/4" OD x 3/8" ID x Many Lengths Round by Metal Spacers Online (1-1/2" Length, 2): Amazon.com: Industrial & Scientific
Yes I had to run spacers. Just like the picture above. I will get pics for you later today.
