Canadian part links
Yammybound88
Links I order from and will have parts as the T7 comes our way.
fortnine.ca
gnarlyparts.ca
dualsportplus.com
dirtracks.ca
mx1canada.com
revco.ca
gpscity.ca
Edited by GPSAT
James 2021 Tenere 700 - Black
Dual Sports Plus has confirmed they will have the Outback Motortek crashbars and other accessories as soon as they are available. They carry Enduristan and other great brands as well. They are located in Brantford, ON. The R&G stuff is well priced on many of the sites posted above. It was marked way down around Christmas.
Edit: Just noticed its marked down again and bought the case covers. Good deal
Edited by tenerecanada
  • 4 months later...
Bumping this back to the top. I am going to order the Yamaha LED 'Plus' Indicators front and rear at some point. Curious if any Canadians are doing the same, and what supplier you are going with. I see them on Rugged Roads site, just hoping for something closer to home. I will see if my local dealer can bring them in when I pick up my bike next week. Cheers.
Stylish rear indicators with integrated tail and brake light which can be combined with the optional LED Flashers Plus Front
Part Numbers:
Front YME-FLB2F-10-00 – Black
Rear YME-FLB2R-10-00 - Black
I just installed these last weekend. Before you try to install them put the little metal pins in and then use a bolt and nut to tighten the 2 pieces together so the are nice and tight. Push the covers on and tap them with a rubber mallet to make sure they are set. The right side is a breeze. The left side I had a little trouble with. The bottom bolt leaks oil out when on the sidestand. Putting it on my swingarm stand or centre stand if you have it stopped the flow of oil.
Cheers.
Edited by DWEL700
Cheers.
Did you fix the problem, were they hard to install?
seeing as they are on sale now, am debating buying a set, though if it's leaking oil, then doing more harm vs good. Also do you have to drain the oil to install them?
Edited by ScorpionT16
NO they don't leak after just when you remove the bottom bolt while installing. Put it on a centre stand or swing arm stand and its all good. No problems at all after install just when you take that bolt out on the left side during install.
Edited by DWEL700
No you do not have to drain the oil. It is an easy install but I just thought I would warn of the left hand side bottom bolt.
Good memory! Thanks man appreciate the heads up - should only be a day or two out.
I bought the Unifilter foam filter from Touratech Canada. They had it in stock and it only took a couple of days to get it.
Another advantage of the filter, made of high-tech foam, is the long service life. The filter is not thrown away when it's dirty but rinsed out, lubricated again and used time and time again. So you don't just take care of your engine but also your wallet
I ordered right from Australia and also the pre filter. $106 Canadian for all 3.
Yamaha XTZ 690 T7 Tenere 2020
Edited by Limey
Thanks for the info. Ya, I was trying to support a Canadian business, but I do want the pre-filter, which they did not have. I will probably order another set from Australia then. EDIT: I just did order everything from there! All I need now is for the darn bike to show up!
Edited by brianq103
