OK Team, I'm having a problem with my rear brake. 2022 with only 900 miles. The other night, I take a quick run to the store and came to a stop at a stop sign. Got going and when I pulled in the clutch, noticed it lurched forward. Shifted and kept going and noticed again, a lurch when shifting. When I got to the store, only about 2 miles aways I put it in neutral and noticed I couldn't move the bike. It felt like the brakes were clamped down. I got back home and parked it and sure enough, the rear brake disk was hotter than hell. I put the bike on the lift and pulled in the clutch and couldnt physically spin the rear wheel, nor would it spin when in neutral.
So I figured the next morning I'd take a look at see what's going on.
The next morning, the bike was still on the lift, in neural and I was able to spin the rear wheel like nothing ever happen. the rear pads had released on their own. I pushed on the rear brake pedal, and it would stop the rear wheel spinning it by hand and then the pads release like they should.
So I took it for a spin around the block, got to a stop sign, using the rear brake to stop, got going and sure enough, the exact same thing happened, the rear brake was trying to stop the rear wheel from spinning and not releasing when i lift up on the rear brake lever. Rode it back to my shop and that disk was hot again and couldnt spin it by hand up on the lift, but just a half hour later and it was able to spin freely.
The rear brake disk is now discolored, almost anodized looking on the inner part of the disc, from heat Im guessing.
I thought "I wonder if it would happened just riding the bike and not using the rear brake to stop and only using the front", so i rode for a couple miles and just used the front to stop and the rear wheel moved freely the entire ride. So the front has nothing to do with it.
I'm not a brake guy, so I'm at a loss of what could be causing this? Any suggestions on how to trouble shoot or reasons this could suddenly be happening?
johnnygolucky
Much appreciated on the insight.
Edited by johnnygoluckyLink to comment
23 answers to this question
Register a new accountSign in
