Rear Luggage rack + tail tidy??
motonap
Hi there,
I have installed the Givi SR2145 top box mounting kit on my T7 and it slowly dawned upon me that I may eventually not be able to install a tail tidy on the bike due to the mounting points that are used for the top box are the same as what will be used for the tail tidy kit. Anyone else on here have gone ahead and managed to get the two together successfully? If so, which tail tidy kit did you use?
I am not looking at changing this mounting kit since I do carry a fair amount of weight in the top box when I travel, so like the double up on arms for support/strength.
2 hours ago, motonap said:
Hi there,
When you install a tail tidy, you're removing all (most) of the OEM parts back there. The TT bracket simply goes were the OEM bits were so there shouldn't be an issue fitting with the cargo rack in place.
