Hello,
How much excess watts does the T7 produce?
How many pieces of heated gear can the T7 take without issues?
Jacket
Max Heat: 135° @ 77W
Power 12V DC 6.4 Amp
Gloves (each)
Max Heat: 135° @ 13W Each
Power: 12V DC 1.1 Amp Each
Pants
Max Heat: 135 F @ 44W
Power: 12V DC 3.6 Amp
thanks
I have a jacket and gloves and the volt meter doesn't change when i turn them on.
  • Members
As far as I remember, the T7 has a very powerful alternator, 400W or so. It's actually good to "consume" the generated electrical power, because it otherwise will just be dissipated somewhere else.
I run a 90W heated jacket, heated gloves and heated grips and my volt meter doesn't drop below about 13.6v while above idle.  I would say the only caution would be is to not idle for extended periods with all this stuff running.
  • Members
I think even idle should be no problem. But no real idea how much wattage is needed for ECU  and plugs and so on. Or at which voltage it will fail.
