Posted January 17, 20232 yr I’ve had a look through the posts and can’t see anything… I stopped to fill up with fuel in my way home tonight and on knocking the bike into neutral didn’t get the green light in the dash, didn’t think much about it until I went to move off and still no light… and wouldn’t turn over : ( wiggled the wires behind the clutch lever and got the light in momentarily and it fired up, now it’s gone out again… anyone experienced this? Any thoughts?
January 17, 20232 yr Moderators Sounds like a loose connection, sticky switch and/or a loose ground. On the last page , #472, is the wiring schematic you can use to trace down the neutral indicator light (#53) and clutch switch (#74) wiring. T7sh.pdf Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again! "Men do not quit playing because they grow old, they grow old because they quit playing" Oliver Wendell Holmes - Mods - HDB handguards, Camel-ADV Gut guard, 1 finger clutch, The Fix pedal & Rally pipe, RR side/tail rack, RR 90nm spring & Headlight guard, Rally seat, OEM heated grips- stablemate Beta 520RS
January 17, 20232 yr Community Expert Before ripping anything apart, give everything a squirt with wd/electrolube first. Even jetwashing can play on the electrics until it’s dry. @wardylondon also had issues with electrics today most likely due to a quick cold snap. Edited January 17, 20232 yr by Dougie
January 17, 20232 yr Author 25 minutes ago, Dougie said: Before ripping anything apart, give everything a squirt with wd/electrolube first. Even jetwashing can play on the electrics until it’s dry. @wardylondon also had issues with electrics today most likely due to a quick cold snap. Funnily enough first thing I did when I got home was give the micro switch behind the lever a good soaking with wd40… seems to be working again now 🤔 I ride all year all weather so it’s possible it was just cold and wet… 🤷🏻♂️
January 18, 20232 yr Author Lost the green light again on the way to work…. No light now won’t start 🤦🏻♂️
