Skid Plate for HeavyDuties Bars ??
john_aero
I have some Heavy Duties Enduro bars on order
Does anyone know what sump guards will fit with these bars?
- Touratech look like may fit and there is TT dealer in Ireland fi could ask if could test one
- Also the Acerbis is cheap and look like a mid way between a decent alu plate and stock one. Just not sure if its Euro 5 fitmament
   Acerbis Yamaha XT 700 Z Ténéré, skid plate - motoin.de
made from  21.3 mm with 2.6 mm thick wall steel pipe Designed to provide maximum protection Includes left and right crashbars MIG and TIG welded for extra strength Protected against corrosion by electrostatic...
Edited by john_aero
Heed plate looks low enough around the sides.  Might email them and see, don't like the lip at rear looks more like would cause it to snag or hook up than slide over anything
https://heedshop.eu/en_US/p/Engine-guard-for-Yamaha-Tenere-700-since-2021-EURO-5-aluminium-raw-unpainted/643
Edited by john_aero
I have the HD Enduro with an AS but i had to massage the top a little outwards.
on both sides or just the right side?
On both sides buti also have a Euro 4 bike. Don't know how many differences that has.
Hard to tell,
i do like the price too of the Advspec plate
Looks longer more than higher and less streamlined
Edited by john_aero
That will easily be massaged. Just a mallet and a sandbag or other soft base, just like i did.
Edit: On my site ride4life.nl you can find a blog where i mention it.
Edited by Ray Ride4life
cheers ill have look and see if can find it
I cant view images on your site from my work computer
I have also the low Heavyduties crashbar. And the stock Yamaha (Rally edition) skidplate.
The aluminium of the stock skidplate is really soft. Just take an simple jigsaw with a blade for steel cutting, and just simply saw-out the part that blocks the bar.
The cuts are in this material are nice. And even if you don't like it, most of the edges are, after installation, almost invisible because of the positions of the crashbar.
The part that has to be cut is approximately as the red dots I've drew on the computer. I am not near my bike at the moment, if else I would have shot better pictures if the part that I have cut.
Ps. I don't think it affects the structural strength of the skid plate a lot.(at all)
1 hour ago, RWM33 said:
On a '21 T7, I have the HeavyDuties Enduro crash bars with the Camel ADV T7 Gut Guard Skid Plate. No installation issues whatsoever.
realy that’s good to know as I’m looking at a camel-adv exhaust
I just got my adv spec euro 5 plate today.
still waiting in the crash bars
once arrive ill Update with fitting and if there are any issues
