Aftermarket Air Filters... Best?
roygilbo
Hi all, looking to upgrade to a new pre-filter/filter and was wondering what you have installed and why?  Also, would you or have you had to have your ECU reflashed to reflect the new filter set up?
I reside in Canada, so the closest solutions the better.
Funnel Web filter and prefilter.
Or Unifilter; the original Aussie made pair
The stock filters seem to do a good job of filtering the dirt
(Pictures courtesy of @Camel ADV )
I'm using Unifilter pre filter, they are the cheaper option, yes they will wear holes in them from rubbing on the underside of the tank eventually, but I got over 10000km before this was an issue, cleaned up and a dab of silicon in the hole and still using, I carry two extra preoiled with me on long rides, rarely ( almost never) have to clean the main filter.
3 hours ago, katana said:
I have 2 FWF filters for my KTM 300.  They are a pain to clean.
Something I didn't consider about FWF.
Unifilter is a breeze to clean.
I run the stock filter with the snorkel removed and a Twin Air pre-filter.  The stock filter is still pristine even when the pre-filter gets dirty.
My ECU was flashed by 2WDW for this setup with a CamelADV exhaust.
If I had to do it over again, I would do the same.
