Posted February 12, 20232 yr I cleaned my airfilter and relubed it with motul foam air filter spray (I have a foam air filter). When I went to start the bike, it caughed a few times and didn start, I had to try 3 times to get the bike running. Is this normal or did I add too much oil to the foam filter? What should I do, or do I need to do anything?
February 12, 20232 yr Moderators Sounds like too much oil restricted the air filter. Try washing it again and " lightly" oiling it, you might be surprised how a little amount of oil can be worked into the foam element. "Men do not quit playing because they grow old, they grow old because they quit playing" Oliver Wendell Holmes - Mods - HDB handguards, Camel-ADV Gut guard, 1 finger clutch, The Fix pedal & Rally pipe, RR side/tail rack, RR 90nm spring & Headlight guard, Rally seat, OEM heated grips- stablemate Beta 520RS
February 12, 20232 yr Community Expert 2 hours ago, SamiNami said: What should I do Try starting it without the air filter. If it runs, the follow AZJW's suggestion. We are all tattooed in our cradles with the beliefs of our tribe ~Oliver Wendell Holmes~
February 13, 20232 yr I also had this issue recently. Oz delivered bikes come with the UniFilter foam air filter. I washed mine, then reoiled with Motul filter oil & found the bike very 'flat' & sluggish. Did some research & UniFilter recommend using non-synthetic engine oil only, then squeezing out as much oil as possible prior to installation. According to UniFilter it is impossible to remove too much oil!
