Yamaha Welders
john_aero
Was out in shed today getting ready to continue with my patio steel framed pergola.
so while tidying up my tools i was taking few sneak peaks around bike and decided how well does the Adv spec sump guard fit up
then as looked closer seen the welds on the exhaust
man I'm no welder but these just look awful. loads little pin holes in the welds, none look to be straight into pipe but a lovely spot for corrosion start and rot a hole in few years.
Ill probably pop these off some point, tidy them up and maybe weld up the few holes
below is one pic where the cat is located, there are more areas like this on the header
Edited by john_aero
Its stainless steel. I wouldn't worry about it.
didnt check, but ill prob polish, clean and tack weld each pit to stop dirt gatehring and slowing rusting them over time
when compare it the the camel-adv exhaust welds its some difference
Edited by john_aero
Professional opinion; TIG not MIG to repair. And use a purge hose.
When welded it will require passivating to avoid corrosion fatigue cracking.
Don't be tempted to use HF acid passivating paste unless you have the correct PPE.
Try and get hold of a TIG brush for passivation
17 hours ago, john_aero said:
... then as looked closer seen the welds on the exhaust
man I'm no welder but these just look awful. loads little pin holes in the welds, none look to be straight into pipe but a lovely spot for corrosion start and rot a hole in few years. ...
You worry too much. Just ride the bike.
Inconsequential on a mass produced stainless header with a cover.
Just ride it.
yes i hve a DC tig welder and was going just massage in the metal,
the current welds look like mig though, or else they were hand repaired or finished by hand Mig
  • Dislike 1
yes i wil agree i am too anal and negative on anything i own. however i enjoy working on bikes probably more than i do riding them 🙂
