Canister removal . Euro 5
razz007
Hello everyone , so what I did was un -clip the pipes from the can and pull the can out . Cut the pipe that comes from the T and bung with bolt as dowel has hid up . Pulled the pipes from the solenoid and used the longest one to run from valve and down beside sprocket . Put two pieces of pipe on solenoid and block with bolt . Sorted . Thanks for the awesome info on here FF2FF10E-B018-4A12-B6F0-E803EAF10D47.jpeg.57f832c0c155ce330286c91b17a6bddd.jpeg13862238-F159-4796-9218-CE1CE2DD8E81.jpeg.9c7a3fbb4e3c1df8fbaa2e1481c581be.jpeg8EF11662-89B1-4987-AAFC-1640CBD83C80.jpeg.33ad8ace0385572efb56720598899645.jpeg
Why? Bike starts and runs fine with it.  Saves no weight. Seems more like an “I don’t like government intrusion in my life” protest action.
Reading on here about hot start issues , and if this summer is like the last , I don’t fancy having that issue . It’s very easy to put back if I felt the need . And the hole reminds of my Gen 3 MT09
@Black99S @DanDoesStunts Here's some background on the issue some owners have had.
I had hot start issues with mine. Removed the canister a year ago and haven't had one since.
