Luggage to fit Adventure Spec racks
DaveT7
Having recently bought a T7 with Adventure Spec side racks already fitted, I was wondering what soft luggage will work well with them? ...or conversely, is there anything that just doesn't work with the AS racks? Thanks.
Depends on how much you want to carry i suppose… i have some dry bags tied independently to the side racks and tail rack.
wolfman yellow bags, green chile adv gear for water bottles/gas bottles, bikemaster net and a larger Sea to summit dry bag. A small tank bag up front and you can carry wuite a bitFFA7BB70-98C2-4AFF-9597-5F4A77E19078.jpeg.fd2b429ebfe3be81588e429dd2bda8de.jpeg892E3AA8-7BBD-4A49-9ABC-B19CF30A6361.jpeg.dbd7e6f97fba3a1bebe832a312543fd1.jpeg
I have the exact same set up and I have the Mosko Rackless 80. It works great.
@DaveT7 I use my Yamaha FZ/MT-09 (made by and available asm SW Motec Blaze pannier) saddle bags. They are a grand job.
71093234604__B839D021-2FCD-49B4-BDEE-1B9A235368CE.jpeg.336ca1d1c6c0ec95d4f83c3a8296cb7f.jpeg
I use Giant Loop Siskiyou panniers with AdvSpec racks. They're great.
Edited by Uncle M
On 4/3/2023 at 7:06 AM, Hollybrook said:
I use Kriega OS-12 on mine.
Do you have the A-Spec upper rack, and does the OS Base fit under the handles or does it have to go over?  Do you have pictures by chance?  Thanks!
I bought the same side racks yestarday in Spain for put in the, the rhinowalk soft bags MT1448BK, combined with : kRIEGA OVERLANDER-S OS-FOOTREST ELIMINATOR YAMAHA TENERE 700 STANDARD, and  I´m still looking the lightest solution for the rear. At the rear, you would only need one point to tie down the bags, something similar to the Kriega anchor point on the footrests.
I attach the OS bags directly to the bike without using an  OS-Base.  The top straps go through some plastic Ali Express handles I have and the bottom straps go through the AS side racks.  I have a CamelADV rear rack, but that does not do anything for the side bags.
Here is a side photo without the bags attached.
Thanks for the reply! You have a nice setup!
Thanks, it has been tweaked many times to get where it is now.
