Team,
The three bolts as marked on the left hanger.  Probably 8mm thread.  Anyone know the correct torque?  TIA.  Neil
  • Community Expert
  • Members
I've also searched for the torque when I removed my center stand - couldn't find it.
The lower bolts are stainless, not sure if it was M8 or M10. I looked up the "standard" torques for stainless bolts on the web, and found it differs quite much depending on the strength of the steel. I think I chose a rather low torque and applied blue loctite (not too much).
It's been about 3 months ago - I'll walk into the garage and check if they've come loose.
  • Community Expert
About 28nm for steel on steel normally but as @Tenerider says, I’d do no more than hand tight with loctite.
Don't fixate on torque values.
Those are most important for engine parts and front fork.
Just don't overtighten and if you're afraid it is not tight enough use a little Loctite.
23Nm on the top one
52Nm on the bottom two
  • AZJW changed the title to Bolt Torque settings for Foot peg mount?
  • Community Expert
  • Members
41 minutes ago, DanDoesStunts said:
23Nm on the top one
Great! Did you find it in the service manual? I think I've searched it over and over again and wasn't lucky. But maybe I'm mixing it up with the screws for the pegs...
