Posted June 27, 20232 yr Hi All, I've read through the posts on the charcoal canister delete (i'd like to ditch mine and make room for a tool tube), however none of them mention anything regarding possible fault codes being thrown up. I've seen this 'kit' which with the electronic Purge valve eliminator contained in the kit would suggest that if one is not used you will get errors? Appreciate your opinions on the above - cheers guys. YAMAHA TENERE 700 2021 - 2022 EVAP / Canister Removal kit Description The EVAP System removal kit by SmartMoto combines the electronic Purge valve eliminator with all the required hardware to let you remove the EVAP canister, valve and tubing from your motorcycle completely. Key...
