Posted July 31, 20231 yr I'm looking for a tank bag that's: - small, but big enough to fit 11 size shoes - has a through-hole for a phone charger - clips away somewhat easily to aid refueling I'm not a real allroad rider (yet), the intended use is for commuting and (when travelling) as an addition to my Kriega OS luggage. I've been looking at SW Motech, but they have so much options I can't see the forest for the trees. Also I don't really like the 'ring' they work with. I like the Giant Loop Fandango, but I'm not sure about the phone compartment. It looks like it can get very condensated under there (on the pictures). Also they look a bit pricey (but that might just be my Dutch upbringing). Does anyone have some suggestions/experiences?
July 31, 20231 yr Community Expert Members Mosko Moto Nomax might be just big enough for your shoes. Or another Mosko. They clip away easily and you don't need any visible mounting points.
July 31, 20231 yr i have the sw motech pro, daypack one on a magnetic ring. top quality, fitment and adjustability.
July 31, 20231 yr Author 1 hour ago, Lewie said: Would a tail bag be better ? I would have to run a long USB charging cable from the dash then 😉
July 31, 20231 yr Community Expert I have the sw motech yukon 130, 13-17 liter. For manys years now. waterproof, zipper goes 2 ways , so i can put my telephone charge cable to the dash and still close the bag. One strap aroud steeringhead, 2 others with click system. Open one and move tankbag aside to fuel up. I think its replaced with this one. SW-Motech SW-MOTECH TANKTAS PRO ENDURO WP 11 LITER SW-Motech SW-MOTECH TANKTAS PRO ENDURO WP 11 LITER voordelig kopen bij Louis. Topmerken ✓ Groot assortiment ✓ Geen risico ✓... www.bikebrothers.nl
July 31, 20231 yr Community Expert 13 minutes ago, leclerq said: I would have to run a long USB charging cable from the dash then 😉 You could put a cable directly on the battery freeing up the dash port
July 31, 20231 yr Community Expert Yamaha has an oem t700 tankbag, looks same as sw motech. Art nr BW3-FWTBG-00-00 www.bikebrothers.nl
August 1, 20231 yr Community Expert Nelson-Rigg Trails End fits that description and is not too spendy.
August 1, 20231 yr 21 hours ago, leclerq said: I would have to run a long USB charging cable from the dash then 😉 I think you should run the Nelson Rigg tail bag. There are 2 sizes. If you need to charge your phone while in the tail bag, use a battery pack. Limited-time deal: Anker PowerCore 10000 Portable Charger, 10000mAh Power Bank, Ultra-Compact Battery Pack, High-Speed Charging Technology Phone Charger for iPhone, Samsung and More. https://a.co/d/bxMqTpL
August 1, 20231 yr I have an SW Motech Evo Enduro, which seems to meet your demands aswell but I don't know if it's still made. I'm happy with it, it's on my bike for pretty much all the time. Just handy to have some space to put all the items that would otherwise make your pockets bulky. And just as @leclerq asked even a pair of shoes, depending on where you're going by bike. Like meetings where you don't want to sit in offroad boots 😆
August 3, 20231 yr Author I ended up buying a (2nd hand) Nomax. It might fit my shoes, it might not, but I can also MOLLE them to the outside if needed 😉 Will report on daily usability if desired.
August 4, 20231 yr Looks like a good choice! The backpack feature seems like a good idea and the overall look is just fine 👍 to suit your needs, you only need the special molle shoe holders and all is fine 🤣 Oh and what I thought to be a joke - in reality it exists (of course): Schuhbeutel – der Schuhbeutel wird mit einem Clip am Molle-Gurtband oder an den Schultergurten deines Rucksacks befestigt Kann auch als separate Tasche...
August 4, 20231 yr Author 7 hours ago, qInvention said: Looks like a good choice! The backpack feature seems like a good idea and the overall look is just fine 👍 to suit your needs, you only need the special molle shoe holders and all is fine 🤣 Oh and what I thought to be a joke - in reality it exists (of course): Schuhbeutel – der Schuhbeutel wird mit einem Clip am Molle-Gurtband oder an den Schultergurten deines Rucksacks befestigt Kann auch als separate Tasche... Lol I might actually buy that!
August 14, 20231 yr Just had this arrive yesterday... The reason for buying this was that the practicality and overall build quality is superb... Thanks...
