Posted August 5, 20231 yr Does anyone (preferably in uk) have any tips on a good (or bad) set of gauges for syncing the intakes? Lots of cheap ones available, but useful notes ( tubes lengths, suitable attachments etc) on ones people are are happy or unhappy with would be handy. I’m looking for a set now. Are people using multiple gauges or the Morgan carbtune type? thanks
August 5, 20231 yr Moderators @Dougie I've used the Carbtune system for years and it's served me well. I used it on my 4 cyl FJR multiple times, no issues. Full disclosure, I haven't yet synced the T7, thanks for the reminder I need to get it done. 😉 "Men do not quit playing because they grow old, they grow old because they quit playing" Oliver Wendell Holmes - Mods - HDB handguards, Camel-ADV Gut guard, 1 finger clutch, The Fix pedal & Rally pipe, RR side/tail rack, RR 90nm spring & Headlight guard, Rally seat, OEM heated grips- stablemate Beta 520RS
August 5, 20231 yr Author 4 minutes ago, AZJW said: @Dougie I've used the Carbtune system for years and it's served me well. I used it on my 4 cyl FJR multiple times, no issues. Full disclosure, I haven't yet synced the T7, thanks for the reminder I need to get it done. 😉 Thanks, it looks like a simpler set to use with no fuss. 👍
August 5, 20231 yr A differential manometer is easy & inexpensive to make...see details in my blog post Tenere 700: Throttle Body Sync Procedure Yamaha Tenere 700, Yamaha Super Tenere 1200 ES, Ride Reviews
August 5, 20231 yr I prefer using the Motion Pro Syncpro which you calibrate every time you use it. I also have the Carbtune II, but imagine that the fluid in the columns with the syncpro avoids any stiction possible with the stainless steel rods in the carbune.
August 6, 20231 yr I am currently using the Motion Pro for my four cylinder bike and plan to use it on the T700 when it's time to sync. I like that you calibrate it before each use, which leaves me confident it is working correctly. You can change the sensitivity by replacing the fluid with ones of different viscosities. Mine currently has antifreeze with a drop of food coloring which seems to work well. Edited August 6, 20231 yr by Hollybrook
