Ntik
The bike will do it for sure. It’s far more down to your ages and your size heights weights etc and your abilities etc.
19 minutes ago, Ntik said:
I have heart that the machine is not for a travel with two people together is tru?
The only reason not do could be this (manual page 6-18):
Forget what you heard.... I don’t get why you are asking as you say you have the bike and you have the wife. So go for a 100 km ride and if that does not answer you own specific question / requirements then nothing will. I’d say less reading and more start doing and trying for yourself.
PS Why the generic photos 🤔
13 minutes ago, Ntik said:
bikeever thanks . The 190 kg is max. Up only five or ten kg is dangerous?
I think its your own risk. Manual is clearly (also manual page 6-18):
5 minutes ago, Ntik said:
Bikeever risk of splitting place?
If you are unsure, whatever you plan to do with the tenere should be within the specifications...
Otherwise:
Thanks bikeever and sorry because i write with translation..
No problem. But don’t get me wrong, if you want to run bike out of specs, you have to make your own experience...
61 + 72 = 133 kg.
So 133 is ok as 133 is lower than the 190 kg maximum limit.
I do not understand your questions; why worry or ask.
Just simply go out and ride it with her on the back on a shorter journey first.
I've done 4500 km with this bike like this, probably it's passes the 180 kg with me, my wife and all the acessories, and no issue at all...
And it was my best time in a bike, with the T7 i hope one day do Lisbon - Rome.
But i will love take a month of vacations and go to Russia, 10 000 km eheheh
Edited by Lupan
49 minutes ago, Ntik said:
Xplane thanks for help and sorry because i write with translation. I ask. If my wife is comfortable with anatomical yamaha oem seat at mini travel 350km
Ok Ntik. I believe that your wife will be best suited person to answer.
So, I repeat “ride it with her on the back on a shorter journey first” then ask her.
Sorry, I cannot help you with this.
