Radiator/cooler fan stopped worked
I’m having problem with the radiator/cooler fan of my T7 after a river crossing… temperature are fine when on highways, but start heat up when on city and I realised the fan is not working… do anyone has any suggestions? Checked fuse, it is good… could it be any electrical connector? Temperature sensor? Or is that the fan itself?
Please, if someone had same or similar experience and found out what was wrong, I’d really appreciate any help!
Thank you
*** ALL SORTED, it was an electrical fan connector. Cleaned, dried, wd40 sprayed and test showed it is working now! Thanks for the prompt answers!
Edited by Gus_S
Problem sorted!
The fan starts working above 107 C. Did you reached this temperature?
I would check the connections to the fan, loose them, spray wd40 or something in the connectors and make a test ride.
Yeah, as @BikeBrother says, clean up and protect the connectors, and check the fuse. I’d also lube any other connectors that were soaked too, to prevent corrosion even if not a problem yet.
Found it. One of the connectors was wet, dried it and prayed some wd40… fan backed to work! Thanks for the tip mate!
A good idea is to put silicone grease on the pins of each connector you unplug. Eventually all will be much better protected from moisture.
