Have I done this...
Gary...
...correctly?
The HEED bar here, is it supposed to be this side on, as now, I cannot fully replace the basic bash plate. The screw here in the bash plate is out of line...
Correct or swap Heed bar here to the other side???
Thanks...
I'll look at mine and post a picture when I get home this evening if no one else chimes in.
Mine are on the outside
Edited by Jesse
https://heed.com.pl/lib/glmv5g/Inst_Mont_YAMAHA_TENERE_700_Z_BUNKER_160_PL_EN-kpqf2s5s.pdf
outside.
btw dont mount figur 5.  if you crash hard your fraim of the light will bend / break.  i have had this happen.
2 plates are heed. the bracket is Yamaha oem.  [will also break subframe]  just skip that part
have it on for 30 000 km with drops and this is the solution that works best for me.
