T7 expected replacement parts list
ADVUSA
I'm interested in hearing what's missing from the below start to parts that are expected to be replaced on a T7.
In other words wear and tear parts.
brake pads
chain and sprocket
wheel bearings
steering head bearings
oil and filter
spark plugs
clutch plates
clutch cable
Tires
Tubes
Brake fluid
Battery
Fork seals
Coolant ( change every 3 years)  Air filter change @12,000 miles ( if using paper element).
I’ve changed suspension linkage bearings more than I’ve ever had to change wheel or steering head bearings. Especially the lower shock bearing.
Handgrips?
Why the list?
