Will this exhaust...
Gary...
...melt the indicator? This exhaust unit looks great, an underneath & inside mount, the only concern here is that the indicator looks like it may end up like the Toxic Avenger. if so, what would I have to do to prevent the melt-down?
Any links, pictures and videos to any "re-designed" indicator units if there is a concern??????? Thanks......
Thanks...
The tricky part was disassembling the fender to install the wiring and resistors, a bit of melting and cutting with the hot knife was needed.  Get a pair without resistors if you can (and still have good illumination)
