The reasoning for...
Gary...
...the rod through the passenger footrests? I'm taking out the rear end; the suspension, the rear wheel, the swingarm. I'll be doing this when on its centre stand. So, is the bar here necessary when working via a centre stand or is it only needed with a stand stand only? Never worked on the T700 before...living & learning...thanks...
Thanks...
2 answers to this question
  • 1
Since center stand isn't stock, I think this is their general method to support the bike from sagging when you remove the shock. I removed the rear shock using a trail stand and had no issues.
I think Yamaha also specifically says you shouldn't support the bike on the skid plate, so from that context it makes sense that they'd suggest another way to support it.
Edited by random1781
advgoats.com
No idea On center stand the rear wheel is generally off the ground anyway....am I missing something?
