Lowering Link Dimensions
Just Footerin
 Hi, I was going to make a pair of links to see how the bike felt sitting a little lower.  Does anyone know the distance between hole centres in order to lower the bike 15mm ? or there abouts.
Cheers.
Cheers.
These threads should help you.
https://www.tenere700.net/topic/5620-lowering-circle-of-frustration/#comment-73178
Thanks, but I already have the standard links. I think I need to make another set a little longer in order to lower the bike, but I only want to lower it a little bit.  If I had a dimension to start it would save to many attempts until I got it right 😆
Edited by Just Footerin
Try this thread
little down there is some math on the link vs drop/raise
you can then extrapolate those number to your own -15mm.
Thanks, I will let you know the results 😀
