FIXED- Stuck wire in accessory plug.
MotoBum
Hello wonderful folks on this forum. My not-mechanically-inclined self tried to wire in some auxiliary lights on my 23 T7 and pressed one of the wires too deep into the connector and now it is stuck. How should I go about trying to remove this? Is there a release function on this connector? I tried using a pin to wiggle it loose with no luck. I was recommended a depinning tool but I'm not sure that would work since I can't remove the wire that comes out of the back. Thanks in advance.
Edit: Silly me. I just pulled the connector in half. There's a little tab that will release it and I was able to push the pin out.
Edited by MotoBum
Resolved
  • MotoBum changed the title to FIXED- Stuck wire in accessory plug.
