Rim width and tyre size !
Aleksandar13
Hi All,
I am hopefully converting the T7 in a hybrid supermoto soon if everything works well... I will be using stock rear rim and order a new rim in 18inch for the front .
Question is : What rim width do I need to run 120/70/18 tyre ?
Choices are at the moment
1 x 18-250-36 aluminium rim
1 x 18-300-36 aluminium rim
Would really appreciate some input in regards to size of the rim.
Thank you,
Aleks
7 answers to this question
On 3/3/2020 at 10:30 AM, Aleksandar13 said:
Hi All,
Thank you,
Aleks
The wheel builders should know that and give you advice 100% I would say.
But, normally for SM wheels you run a 3.5 width front. Some do run 3, but that's on the smaller bikes I believe
Edited by Rich TT
Hi Rich,
He did mention that both the above are going to fit 120 wide tyre... Was just looking at a second opinion.
The dark web says 3.0 as attached in the picture.
Want to be sure before ordering the rim.
4 hours ago, Aleksandar13 said:
Hi Rich,
I'd say you definitely need a 120 front tyre with the 150/160 rear.
Therefore, I'd go for a 3 or 3.5 ideally. No point in having a narrow rim as you won't need a skinny front tyre as per off road.
3.0 is the only option from this supplier in 18inch... I can get 3.5 in 17 but that's gonna look weird I think.
Paint yamaha blue and some sticky tyres. 🤔👍
Sounds like a plan. You could be the first person in the world to do this, which is pretty cool. Bet you won't regret it!
That's right.. But it is not actually a supermoto... I think its called motard isn't it?
Not sure maybe you know better..
Turn in should be better and bike a bit lighter as well....😬🤩
It will be better on road, I guarantee it. Not that it's not good on road in the first place of course. In fact, it's amazing considering it has a 21 inch front wheel.
Cheers
