So last year I had my banjo bolt come loose while riding the t7 down a dirt road. Lost all my braking pressure in the rear brake, and quite a bit of fluid. Sucked a bunch of air through the line and the ABS/Check engine came on, probably as a result on the loss of fluid ( I didnt notice the leak until my braking in the rear became super mushy and i already lost a decent amount of fluid). I ended up making a post about it in here and found out it was the banjo bolt and tightened that up, refilled with fluid and the rear brake worked okay. Fast forward to now, I bled the front and rear brakes, filled the respective reservoirs to the fill line, swapped the ABS fuse, cleared the check engine light, but the main ABS light still wont go off after 10 miles or so. Is there a special procedure I am missing? Or any tips overall on how I can fix this issue? Would love to have my ABS on road again. Thanks in advance!
TheoremX
4 answers to this question
Register a new accountSign in
