Set my T7 up for Touring
Jayzonk
Hey T7 owners,
I've had aluminum boxes on previous bikes wanted to try something lighter on the T7.  I'm trying to be conscious about how much weight I'm adding to the rear of the bike, as I want to preserve good overall balance and front end feel.  I really didn't do anything to ground-breaking but it did take some trial and error to find the gear that I think offers a significant amount of storage volume for the least amount of weight.
I ended up using the Yamaha OEM tail rack, which weighs about 14 pounds.  I thought this was going to be a mistake,  but it's working out pretty good.  Because it's got a Givi Monokey plate, I could easily attach a Givi Canyon tail bag, which holds 40 litres and weighs a touch over 4 pounds.
I also added an Enduristan waterproof roll bag (40 litres), and two large Enduristan soft side panniers (12 litres each).
This gives me 40+40+12+12=104 litres of storage.   All four bags together weigh 12.3 pounds.   Combined with a 13 pound rear carrier, the entire setup weighs about 25 pounds.
I've had to do some strap trimming to get everything set up, amd there's a little more to do yet,  but it's coming.
Pics or it didn't happen.
Stage 1: added the Techspec rubber pads for the rear to give the sides some grip for the soft panniers.  I wasn't crazy about covering up the original panels but I didn't see any alternatives if I wanted the soft bags to stay in place.
I should back up and tell you that I had already added the OEM rear carrier and the OEM rear seat carrier (mono seat) for holding extra bags on a firm surface.
Edited by Jayzonk
Spelling
This is the OEM rack made by Givi.   It has the posts and the tab to accept any Givi Monokey rack.  I will later attach a Givi Canyon 40 litre bag to this rack. It's a soft pack with a rigid plate for solidly attaching it to the rack, which saves having to strap the bag down.  It's lightweight too, approximately 4.5 pounds in total.
 Notice the extra loops with holes that slip underneath these screws under the seat.  I don't currently use the loops but I may in the future.  Came from Kriega.
Edited by Jayzonk
Here is the Givi Canyon soft tail pack, with a picture of the rigid Monokey base underneath.  The rigidity extends beyond the plate and includes the entire rectangular portion of the underside.  You can see the mounting slots and the latch for connecting to the Monokey plate, plus you can see the corresponding connections on the carrier.
Edited by Jayzonk
The next stage:  adding the Enduristan Blizzard soft panniers.
I've added a stock photo of the Blizzards so you can see the rubberized inside surface, which will mate against the rubber surface of the Techspec pads.
I took the two-inch cross straps and pulled them out of the port side bag.  I bought some extra two-inch poly webbing and ram it through the buckles on that side and added plastic clips on that end and the end of the straps on the starboard side.   I tightened them up and trimmed the excess webbing.  Hang loaded panniers across your bike to determine how long you should leave your straps.
I also sewed extra elastic ribbons and slipped them around the straps to keep the ends lying flat while riding, instead of flailing around in the wind.
I also trimmed the one inch rear connection straps and added additional elastic ribbons to hold those straps in place.
Enduristan_LUSA-007-L_Blizzard_SaddleBags_L_009_1603b4ef-07b5-444a-9c3b-ddc68dd20952_300x.jpg
Here is the rear of the bike, showing the connection strap.  The two metal buckles fit conveniently into the underside of the tail light bracket. It's a perfect fit.   You have to look hard to see the rear strap, but it's there.  I can always take some more pictures.
Edited by Jayzonk
Here are all the bags for the set-up: the two Blizzard panniers (12 litres each),  the Blizzard Tornado roll top bag (I think it's 30 litres, not 40), and the Givi Canyon Monokey tail bag (40 litres).  Total weight is 5.6kg, or 12.3 pounds.
Edited by Jayzonk
For comparison purposes, you could consider an aluminum pannier set , an accessory bag, and a top box by SW Motech.  I really like the quality of their stuff and I've always had good luck with the fitment.  This set weighs 76.2 pounds and offers 150 litres of storage (120 litres with the panniers and an additional 30 litres with the accessory bag that lashes to a pannier top).  This is 59 litres more than my soft bag setup but it also weighs three times the amount.   I guess which one is right would depend on what needs to be taken on any given trip.
Edited by Jayzonk
Here's the final setup.   There's still a few straps here and there that need to be trimmed and tucked/tied-off.
I used some Rokstraps to secure the seat bag - two fore and aft on either side, and two cross-corner ones.   I'll likely take the setup for a test spin and make some adjustments.
You could also go to the new SW Motech semi rigid DUSC thermoformed ABS plastic system.  With two side carriers (carriers weigh 13.6 pounds total) and two panniers,  you get 74 litres of storage with a weight of 39.8 pounds, so it's lighter than the aluminum set but still not as light as just using the OEM tail rack (total system weight = 25 pounds).
If you add a DUSC pannier as a tail pack system, you add 41 litres at a weight cost of 21.9 pounds, which includes the rack and mounting plate.  That puts you at 115 litres and 61.7 pounds, compared to my 104 litres at 25 pounds.
Rackless is the way to go.  It requires a little more setup time, but once you've established your strap lengths and your stash points for excess strapping (to keep them from getting caught in moving parts like the chain or wheel), you're better off from a bike weight and feel perspective, especially at low speed.  The stuff stores compactly too.
I do keep one Givi thermoformed tail pack for commuting- because it's semi rigid,  I don't have to worry about packing it full to make the system work.  It's a Monokey so it clips right into the tail rack.
How much under seat storage does the mono seat cover thing add?
It gives you some extra clearance for more tools or something else you've flat-packed yourself.  A tire tube could go under if you took it out of the original cube box and flattened it out.
The mono seat just pops on and off through the key latch.
  • 6 months later...
Test run on Ontario highways went well. Stays stayed tight.  Load was balanced.   It's a little difficult to see how the panniers were loaded. Will send better shots.
Edited by Jayzonk
Do you have any issues locking the Gigi canyon on over those straps? Thanks
None whatsoever.   The straps from the side panniers go over top of the Yamaha mono seat, not the rear rack.   I do not have any straps crossing the top plate on the rear rack, and I therefore do not know if the givi bag would lock into position if there was a strap passing underneath it.
Edited by Jayzonk
Im surprised you didnt go with the Givi Canyon side bags except that they require racks.  Thats a set-up Im thinking about right now.  I currently use Tusk rackless for day trips and they work good except kinda difficult to get things in and out of.   I also (very rarely) use  Tusk Pilot panniers on my SW side carriers if I'm going to have a very long off-road orientated day trip that "might" require an overnight stay.  They work pretty good too (and carry the weight very low- I like that) but they are very fidly with how they strap to the side carriers.  My SW racks are already set up to take Givi Monokey Alaska cases so a move to the Canyons would be nice I think.  I just dont use that set up very often to justy the cost. Anyway, your set up looks very good!
