Today I changed my sprocket for the first time (upgraded from 15 to 16 tooth).
During the change it was the first time for me to work with a "punched lock" type of sprocket.
Because the threads of the nut are deformed due to the punching, even after bending the punches back with a screwdriver you could potentially damage the output shaft; I saw someone who damaged his output shaft with the stock nut, and therefore was wondering if anyone already tried alternatives for this nut?
For example, with my other bikes I am familiar with a "bend washer" type of lock?
Made a simple sketch of what I mean:
(This is what I am familiar with from my other bikes)
Seems less risk then the OEM nut in my opinion?
Not sure if this will work with the Tenere output shaft dimensions with the OEM sprockets, cause this will require approx 1mm of length on the spline (gear shaped part of the shaft), but maybe someone already tried something else then the "punching" method?
Zefiros
Hi all,
Just wondering
2 answers to this question
Register a new accountSign in
